Website access problems - nearly a solution!
  • KitCarGirl
    • 720
    Hi to all of you who have been having problems accessing the website for months.
    Please try using the following link for the next couple of days. We are then moving to a NEW server and hopefully all your access problems will melt away.
    http://www2.marlinownersclub.com/
    Can you please let me know if you are able to access via the above link.
    Sue
  • Peterx
    • 361
    Re: Website access problems - nearly a solution!
    Hi Sue,
    direct access is now fine but the links (Sportster, 5exi, misc, etc) on the forum now all go to the same Roadster section?
    The othr links seem to work, but I've not tested them all,
    thanks
    Peter
      • 2809
      As PeterX says, all seems to work except the "Cars" which is not doing anything at all
      XXX
      DC
        Hi Sue.
        I get straight in to the MOC site with no access problems. The forum only shows me the Roadster posts at the moment regardless of which category I select. It's early days yet and look forward to completion of the work.
        Thanks for the hard work Sue,
        DMMC x
        • KitCarGirl
          • 720
          I shall be collecting all these kisses when we finally get a solution!
            • 2809
            Now that's the sort of promise I like !!
            Take your time ref Pitstops
            More X
            DC
              Great, I'll store lots for when we get a solution!
              Dane ∞x
