Marina Instrument Panel Bulb Holders and Bulbs
    • 2454
    Does anyone have any spare bulb holders and bulbs for the Marina Instrument Panel. If not does anyone know where I can get some? Any help will be good. Adrian
    • 2454
    Re: Marina Instrument Panel Bulb Holders and Bulbs
    Also the votage stabilizer is needed, again any help would be appreciated.
    • donsayers
      • 282
      May have a voltage stabiliser spare, I will have a rummage. I used a scratch built solid state one. I can easily build another.
      What do the bulb holders look like?
      Don
        • 2454
        Hi don, If you do have the Stabiliser that would be good and find attached the bulb holder. Many thanks. Adrian
        • donsayers
          • 282
          Found it! Can't help with the bulb holder though. Something similar was used on early Metros might be worth trying Unipart.
          Give us buzz. Don
          • KENGILLOTT41
            • 5
            Hi Adrian,
            Are you still needing bulbs & holders plus stabiliser ?
            I have Smiths regulator BR1303/20 and some bulbs with hodlers which may fit - manufacturer Pressac - look like your piccy but may be Rover 2000 rather than Marina.
            Ken
