Lift-the-dot punch?
  • Peterx
    • 361
    Lift-the-dot punch?
    Has anyone got a 'lift-the-dot' punch that I could borrow? (You'll know what it is, if you've got one!)
    I will pay all postage costs, etc
    My email address is [email protected]
    thanks
    Peter
    Re: Lift-the-dot punch?
    Crikey, I did not know there was one! I use my trusty Swiss Army knife. There are sufficient tools to make the various holes with this!
    • terryreed1664
      • 257
      Never seen one of them before, its not the 1st April is it.
        No Terry, it really is a genuine, Victorinox, Swiss Army knife. I also own a Swiss Navy knife which could, I suppose, be applicable to the end of the Ides of March! I can post a photo if required.........
        • trevor_ford
          • 213
          Apparently they are available -
          eBay Item number: 200085745680
          Buy it Now £47.91 + £4.23 from Canada
          I think I'll stick with a sharp knife.
            I found that if you sacrifice one clip by sharpening the four prongs you could tap the clip down onto a wooden block to make the four small holes then mark the big hole through the clip then use a multi size punch that is like a pair of plyers. Frost have the lift dot punch £50 fffffff how much?
            • Peterx
              • 361
              Thanks, Ben.
              Yes, I know you can buy them, that's why I was hoping to borrow one :-)
              I was thinking along the same lines but hadn't thought of sharpening a spare clip. I'll give that idea a try,
              thanks
              Peter
              • keith_h
                • 549
                Hi Peter,
                I used an ordinary leather belt hole punch with the 6 different rotating heads on it (very cheap from markets). What I did was to experiment with a bit of scrap leather to get the spacing right then it was a doddle. I used the largest hole punch to cut out the main hole (I seem to remember I had to take several extra cuts as the hole was just not quite big enough) and I used the smallest punch for the 4 holes to take the fold over metal tabs.
                  Peter
                  If you are considering buying one, I'll go halves with you. Trying to save a few shilling could spoil a very expensive hood.
                  regards
                  • Peterx
                    • 361
                    Thanks, Mike, i'll keep that in mind. I am going to have a go at Ben's idea above combined with an 8mm punch I have on order. If that looks messy on the first one I do, i'll go for the proper tool.
                    thanks, Peter
                    • Peterx
                      • 361
                      I used Ben's suggestion above today and it worked just fine!
                      Thanks a lot for the idea!
                      Peter
                        Glad it worked ok. Perhaps I could pattern the idea.
