Fuel Gauge reads back to front - a solution
  • almyland
    • 118
    I've just solved a problem with my roadster and the background might be useful to other Marlin owners. I didn't build my car but when I bought it the fuel gauge read back to front ie: full when empty etc. My gauges and fuel sender are made by VDO (still going strong) and are a matched set. The problem arises when the fuel sender is assembled incorrectly; very easy to do. Again it is a simple fix requiring one screw to be released and the float arm reversing. That's it. I have to thank John Gare of ETB Instruments for the technical steer to the solution; we had just about run out of practical options on the roadster forum. I can't praise John or his helpful attitude enough and would reccommend them to any future builder.
    I hope this info proves helpful to someone in the future and I do have a copy of the tech sheet which fully explains the installation of VDO fuel guages if required.
    Cheers Alan
  • Patrick
    • 471
    Re: Fuel Gauge reads back to front - a solution
    I managed to do that as well. I put the sender together exactly as in the instructions - which turn out to be exactly 180 degrees wrong (Fortunately when you pull the sender wire form the gauge is reads full so we were OK for the SVA!)
    Patrick
    http://www.modelog.co.uk/
    http://www.mustang67.co.uk/
