rear suspension
  • mazzjngooglemail.com
    • 9
    rear suspension
    Hi, can anyone with a cortina based berlinetta tell me if I need to use the rear anti roll bar, or is this discarded (the same as the front anti-roll bar)?, Cheers, Jim
    • 1237
    Re: rear suspension
    If you have it then use it. I have seen Berlys with and without, but anything that may help the back end has got to worthwhile.
      • 9
      Re: rear suspension
      Danny, many thanks. I have two, so I guess I may as well use one. Thought that if it wasn't needed would save some money on buying more bushes!!!! Cheers, Jim
        Re: rear suspension
        definitely keep it on. If you have the later thicker one, use that.
