Recommend you check your upper wishbones (and lower) ever so often
  • Patrick
    • 469
    Found a weld fatigue crack on one of my upper wishbones today. From the surface, it looked like a crack in the paint until I took the paint off to find it cracked. The issue was on the weld between the rear tube and the flat that the ball joint connects into.
    I have fixed this, but ideally would want new wishbones, but I guess that'll be quite difficult at the moment give the current status of Marlin Cars.
    http://www.modelog.co.uk/
    http://www.mustang67.co.uk/
    • 931
    This is a good reason not to chrome wishbones...
    • Patrick
      • 469
      I'm looking into maybe adding a gusset between both tubes and the flat metal piece, which would add a good amount of strength
