Berlinetta Cortina Mk 3 brakes
  • metro6r598
    forum contributor
    • Sep 2023
    • 3
    Good afternoon from sunny Cyprus. Reference the above topic. My brake pedal has always been soft with long travel, whilst they do stop me I am looking how to harden the pedal. Find calipers at sometime have been replaced with slightly larger pistons but still have ( just fitted new) original master cylinder, no change in fact could be a little softer. Would replacing cylinder with slightly larger piston be the answer, have been looking at landrover Defender or 110 cylinders. Has anyone done this or other swaps and are they straight forward. Thanks Brian
    • 1237
    Best advice I could give Brian. Try to keep it standard. Change the calipers to standard mk3/mk4 Cortina, make sure you have the correct master cylinder and start from there.
      • 1649
      Best to bench bleed the dual circuit master cylinder before fitting to get all the air bubbles out. Then fit and bleed the whole system as usual. You will be amazed how much of a firm pedal you can achieve with this method.
        if you have a servo then a longer pedal movement can indicate an unserviceable servo.
        • A_Hogg
          • 339
          Fitting calipers with larger pistons MAY require a larger bore master cylinder as you need to displace a greater volume of fluid to compensate. That's why the pedal travel increases. It comes down to how firm you like the pedal to feel. [ Formerly ex Halton brat /airframe tech 216 Sqdn Comet's !]
