marina gearbox
  • bobandjaneburden
    • 38
    marina gearbox
    roadster 1.8 b i can select all gears okay except reverse move gear lever full over to the right and it takes about six goes before it find reverse, once in it is okay. am i missing something in the way i do it ?. thanks for any info.
  • martinclan56
    • Feb 2020
    • 486
    Yes you are missing something! You have to push the gear lever down (or up - I don't remember) to clear the reverse gear indent plate which is there to stop you accidentally selecting reverse.
      • 2454
      If my memory serves me right reverse is engaged with a swift slap on the gearstick. On top of the gearbox (this is accessible from underneath the vehicle) there are two bolts, one with a cable coming out of it (the reverse sensor) and another. This is the one you need to take out, BEWARE THERE IS A SPRING AND A METAL BALL IN IT, you need to put some grease in this and reassemble the bolt. If that doesn't work it could be that the sensor bolt has stuck as well. Use the same process on that and hopefully all will be well. Adrian
      • Ye Ol Ripper
        • May 2016
        • 298
        The gearstick on a 1.8 , has to be lifted at the same time that you move it forwards and across to the right. There is a lift plate fitted to the gearbox that is designed tor restrict a protruding bit at the bottom of the gearstick from being moved to reverse gear without lifting first.
        Otherwise you will accidentally be selecting reverse gear when trying to select 3rd gear as they are both in the same direction.
          • 2454
          I was referring to an MGB 1.8, the Marina 1.8 may have a different gearbox?
