Looking for a single HUNTER Alloy wheel
  • billjackson54
    • 212
    size 15 x 7J, et 35, 4 x 108. Ideally, I'm after a matching full size multispoke wheel to use as a spare on my Hunter. The design is a secondary consideration as it will be boot mounted under a cover.
    Anyone got an odd one or two lying around in their garage that might suit?
  • billjackson54
    • 212
    Actually problem solved...a certain well known auction site revealed a very similar Ford wheel...correct PCD and acceptable offset with the correct number of spokes. As it's intended use is a proper full size spare, it's going to be boot mounted most of the time (I hope!), so few people will notice that it's not a precise match. When it's on the car and in use, it will certainly look better than a bright red space saver...and again it will be a particularly sharp eyed observer who'll spot the difference between it and the others, so I'm happy.
