Fuel tank
    • 2454
    Fuel tank
    Has anyone fitted an MG Midget fuel tank to there Mk2 marina based Roadster?
    If so any pictures would be good.
  • martinclan56
    • Feb 2020
    • 486
    I considerd it but in the end dismissed the idea as nobody else seemed to have done it, or at least was willing to own up.
    In the end I had a tank made - not as expensive as you might think and guaranteed to fit as long as you can use a tape measure :-)
    • 928cdu
      • 230
      I’ve fitted one, but to a Triumph based roadster.. it fitted perfectly and there would be less space in the Triumph version ..I got it new from an mg specialist. It replaced the original imp tank.
        • 590
        Hi Adrian.
        Have you considered a long range Morris minor tank from the MM specialists. This is actually an escort van tank that is modified for MM fitment. Be warned....the fuel neck is in a very different orientation and will most likely NOT work for most Marlin owners. Could be an option though. Just putting it out there.
        There are 2 versions available with different designs. The MM specialists also sell Midget tanks as an option so in theory, they should fit too.
