Plea for pictures - alternator mounting
  • martinclan56
    • Feb 2020
    • 486
    Does anyone have any pictures of the alternator mounting for the B-series engine? My car used to have a dynamo which was already a very close fit to the steering UJ.
    I want to fit an alternator now but beggining to wonder if it will fit in! Alternators tends to be fatter and shorter than a dynamo.
    Cheers, Robin
  • Ye Ol Ripper
    • May 2016
    • 298
    Hi Robin. I will take a photo of my Lucas Alternator tomorrow for you. Incidentally the Bosch alternator from that era has the same mounting points as the Lucas. So you can use either.
    • martinclan56
      • Feb 2020
      • 486
      Thankyou
        Standard Marina alternator (16-ACR if memory serves) fits snugly but belt length matters! I think Marina belts for B-series came in 915mm (early) and 950mm (late) - you'll probably want the shorter of the 2. There is also a 900mm for early MGB, which is tight to get over the pulleys (ask me how I know).
        • TVRFan
          • Jun 2022
          • 41
          The V belts came in many sizes, and part numbers were often their length. I used a shorter belt to squeeze in an alternator instead of dynamo on Triumph 6, front is very close to sides. So should be able to get one that works....
          Alternator mounts are typically shorter in length than dynamo, but details vary. I cut up a Ford mount to move alternator higher on a different kit, (Ford V6 engine) and used angle iron and a bit of welding to get to nearest block mountings. Didn't look very pretty, but it didn't break either, so did the job.
            • 590
            This is the info from the build manual.
            • martinclan56
              • Feb 2020
              • 486
              Thanks all.
              I am intending to use a small and lightweight Denso alternator, in an attempt to keep the weight down (lol), so it seems there shouldn't be a problem.
              Interesting that the MGB belt is 900mm. I have actually ordered an off the shelf 900mm V belt but if that doesn't sit well in the pulleys I can use the MGB one.
              Cheers, Robin
              • Ye Ol Ripper
                • May 2016
                • 298
                Hi Robin
                I am happy to post you some photo's of my Lucas alternator on my 1.8 B series and also the belt length that actually fits ok. However if you plan yo use the Denso then surely the Lucas photos and belt size will be pointless?
                Do you still wish me to crawl under the car as the adjustment bracket is best viewed from below?
                • A_Hogg
                  • 339
                  Most of the Mg specialists [ MGBhive etc] have a Dynamo to alternator conversion bracket if that helps
                  • martinclan56
                    • Feb 2020
                    • 486
                    Originally posted by Ye Ol Ripper View Post
                    Hi Robin
                    Thanks but not necessary unless you want an excuse to play with the car
                    I am now happy that the alternator should fit ok.I had been reviewing pictures I took before the dissasembly and there just didn't seem enough space...
