YKC more suspension help
  • agent leman
    • Oct 2019
    • 43
    And so the rebuild of my YKC's suspension goes on and I have progressed from the back to front end. Here's a further plea for historic parts information - Has anyone got details of the rubber compression / topmount bushes used on YKC Roadster (I guess the same are also used on Romero and Julietta)? I also want to find the spec for the original front springs? The standard springs had been replaced by one of the past owners 100lbs/in rated 10.5" springs that had been screwed up so tight that they were nearly coilbound at rest. With AVO now out of business I have had replacement front struts made by GAZ and I'd like to minimise guesswork and trial & error with the spring rate and length.​ Thanks.
  • A_Hogg
    • 339
    Try posting on Marlin Facebook site. That way you may get Steve Himsworth [ the man behind YKC] to see it. He posts occasionally on there.
    • ykc-romero
      • Feb 2025
      • 6
      Hi there agent leman could you get in touch as I suspect I too am about to embark on sorting my suspension on newly acquired YKC Romero, it has a see-saw feel if you turn the wheel, as if there's zero damping, just springs! Would like to talk to you about what you've had to do... so far.
      • agent leman
        • Oct 2019
        • 43
        Thanks for the advice about Facebook. I have resisted all pressure to sign up to Facebook for years however my YKC restoration may tip the balance ...hmm I will try to hold off for a bit longer!
        • agent leman
          • Oct 2019
          • 43
          ykc-romero. I've PM'd you.
