Door / wing mirrors
  • martinclan56
    • Feb 2020
    • 486
    Door / wing mirrors
    I will shortly be fitting the hood to DRL152K and I need to think about wing/door/etc. mirrors as part of the process.
    Does anyone have any suggestions / recommendations for the best mirror position and type?
    Looking at the gallery there seems to be a lot of options - some I guess better than others. I intend to drive the car regularly so need something practical rather than just chosen for appearance :-)
  • A_Hogg
    • 339
    I had ones from YKC on mine that were fixed to windscreen frame via tapped hole . Did the job for me!
    • martinclan56
      • Feb 2020
      • 486
      Yes - I have seen that many cars seem to have that arrangement. I don't suppose you know who made the mirrors?
      • MOC Chair
        • Dec 2022
        • 235
        Car Builder Solutions have similar mirrors. I use a pair with long arms that are attached to brackets on the front wings when towing our caravan.
        They have a threaded end with a nut so with that removed, they would fit into a threaded hole in the windscreen frame. When screwed in they would need a washer of suitable thickness so that the arm ends up in the required position.
        • romeks44
          • 135
          As a Berlinetta owner I just took a look int Roadster galery to find that most of them have no side mirrors…
          For my cars I’v got Tex mirrors. A quick search for “Tex mirror” on eBay will give you a nice variety of them.
          Roman
          • A_Hogg
            • 339
            Had a look at my son's Roadster and they have Tex mirrors with the pattern number 746275 if that helps. Stalks have no markings so maybe YKC had these made.
            • martinclan56
              • Feb 2020
              • 486
              Thanks for the answers. My car is very early, no tapped holes in the windscreen frame. Looks like I will have to make some :-)
                • 2454
                As you can see mine are attached to the door.
                Due to the thickness of the aluminium they are very stable and as an extra I put a spreader plate behind it.
                You do not have permission to view this gallery.
                This gallery has 1 photos.
