Cabrio / Hunter rear shock absorbers
  • billjackson54
    • 212
    I'd like to change the rear shock absorbers on my Hunter for quality gas adjustable ones. Any suggestions on make, part number and settings gratefully received!
  • A_Hogg
    • 339
    Personally I always thought it was fine on the bog standard Sierra shocks Bill, but your choice. Gaz will probably be able to supply adjustables.
      • 1648
      Check the bottom bolt diameter before ordering. IIRC they are either 10mm standard or 12mm on the XR4i / Cosworth rear arms. I fitted GAZ shocks all round some years ago and they have been fine. Set them to minimum and then increase one click at a time until the rear of the car just doesn’t “bounce” when pushed down and released. Note that the adjusters only provide adjustment, they are not a calibration!
