Marlin Berlinetta gearbox
  • gouldalan
    • Aug 2024
    • 28
    Hi Folks, My Berlinetta is based on a 1976 Cortina with a four speed box. Can you drop a 5 speed box in easily or does that need chassis mount modifications? Just thinking a 5 Speed may give better MPG. Cheers, Alan.
  • daveghunt
    • 71
    Alan:
    5 speed box is a well known upgrade, 5th being an overdrive ratio revs for cruiseing and therefore fuel consumption should be lower.
    The chassis gearbox x member, gearbox mount, will require modification.
    If you search the berlinetta articles you should find details of this modification.
    Hope it goes well, DaveH
    • daveghunt
      • 71
      Further to the above details in Brian Gadd’s article February 1993
      • gouldalan
        • Aug 2024
        • 28
        Cheers Dave
