Ital based roadster
  • daimler
    • May 2024
    • 3
    Ital based roadster
    Working on a Roadster standing idle for 21 years. 1700 Ital based. Suffered through inactivity but hoping the engine has survived the inactivity. Spares hard to find. Watch this space!
    • 2797
    P M sent.........check the top right of your screen for "Notifications"
    • daimler
      • May 2024
      • 3
      Got the O series running. I have set the ignition timing to the manufacturer's 14 degrees BTDC but she tends to misfire,occasionally backfire and carb adjustment doesn't help. All other settings/adjustments i believe are as they should be. Should i alter the timing?
