Roadster Windscreen template
    • 2454
    Hi again all.
    I have a wooden template for the Mk2 Marina based Marlin Windscreen which can be used to cut a new Windscreen from a Land rover one and retain the kite mark. If anyone would like to borrow it I would be happy to supply as long as it was returned. Adrian
  • Gareth
    • 502
    Please keep it safe. You never know when one of us will need it!
      • 2454
      Hi again all.
      Just an update
      The template is for my SWB Mk2 marina based Roadster, the screen at its widest is 95cm the height from the top to where it curves up to the centre is 27cm. Remember that the screen slides upwards into a channel and therefore will be larger than the outer frame. I hope this helps
