Marina based Roadster - front brake pipe route
  • martinclan56
    • Feb 2020
    • 486
    Does anyone have any pictures of the front brake pipe route? I understand that the T piece should be mounted on the offside steering rack support, but where are the pipes routed from there - I can't see any obvious route.
    Also the build manual refers to a tag on the chassis to mount the chassis end of the flexi pipe. Mine is an early chassis - and I don't seem to have said tags. I just bought some standard Marina front flexi's and they don't seem anywhere near long enough to reach the chassis so something is not quite right.
    I know I took the car appart in the first place but I am unable to remember detail like that and the many pictures I took unfortunately don't show that area!
    Cheers, Robin
    • 2814
    • rhysnolan
      • Jul 2023
      • 139
      That pic is the same as mine, earlyish Mk2.
      • martinclan56
        • Feb 2020
        • 486
        Yes that's very helpful. I don't have that tab on my chassis. I don't suppose you have any pictures of how the rigid brake pipes are routed?
          • 2814
          Do you have a build manual ? In it I think there is a drawing for the pipe routing.
          The pic above shows one front wheel pipe and locates the 4 way connector, the other front wheel pipe routes similarly
          • martinclan56
            • Feb 2020
            • 486
            Thank you. I do have the build manual but it's not that specific. But I think I have enough to move forward now.
            Cheers Robin
