Grille emblem
  • Club Member
    • Jun 2023
    • 10
    Grille emblem
    Hi does anyone know where I can get a Marlin grille emblem
    Occaisionally on Ebay!
    • rhysnolan
      • Jul 2023
      • 139
      I could get my son to copy mine and 3D print, either as a casting pattern or use as printed.
      • A_Hogg
        • 339
        Think the last one I saw on e bay was £50!
        • ggrum
          • 785
          Is this what you are after? Its about 5" long with a couple of threaded studs on the back for fixing. IMG_3350.jpg
          • Patrick
            • 464
            Should be possible to draw one up in Illustrator or Fusion 360 for laser cutting in stainless, would polish up quite nice.
            I guess the people that bought Marlin are not supplying parts yet? The website still says it is for sale.
            I've got the one for my Sportster in a my display cupboard - I run the car incognito without any badging - other than on the gauges.
            http://www.modelog.co.uk/
            http://www.mustang67.co.uk/
            • Club Member
              • Jun 2023
              • 10
              Thanks for the replies, at the moment I am looking to get get one waterjet cut from 1.5mm stainless
              • rhysnolan
                • Jul 2023
                • 139
                I do have a good contact for effectively priced cutting, although £25 minimum which might have several done if you wanted to share them around. I could check if you wish?
                The one on my car is circa 10 mm thick, cast and chromed.
                • rhysnolan
                  • Jul 2023
                  • 139
                  The one on my car would readily work as a pattern for a silicone rubber moulding, so I think I will do that, just because I can, and then take a copy for the display cabinet. I have done other car ones using various fillers in the resin, brass powder for the vintage Peugeot one which polished up just like metal. If the OP wants I'll happily do one.
