Gt6 overdrive gearbox
  • Club Member
    • Jun 2023
    • 10
    Does anyone know if a GT6 overdrive gearbox will fit onto a 1360 bell housing , I have been offered the gearbox by a friend, since owning my herald based roadster
  • TVRFan
    • Jun 2022
    • 41
    I think it's the same gearbox, but probably ratios are different. Maybe first is higher for the l6 engine, but shouldn't matter all that much with lighter vehicle to push. I suggest you go and have a search around Rimmer Bros website, they have a lot of diagrams and information to compare. You will probably have to change speedo gears to get right MPH displayed....
    Just needs a bit of research to double check.
    • martinclan56
      • Feb 2020
      • 486
      And I guess you will probably need to shorten the propshaft as the overdrive box is longer.
