How to post pictures
    • 2814
    To add pix to a typed reply on the Forum, when you’ve finished the typing, leave the cursor where you want the pic to go, then
    hit the Upload Attachments button.​
    Select the pic you require, then hit the size you want to put up (remember that a max of 600 in either direction will be good)
    If you have picked the wrong size, hit Remove and try again.
    Do the same again if another pic is wanted
    Then hit Post Reply button bottom right
