Wanted - Marina front suspension tie bars
  • martinclan56
    • Feb 2020
    • 486
    I have bought the bits to make the front tie bars adjustable using turnbuckles and rose joints.
    Rather than chop up the perfect tie bars I have, has anyone got any that are past their best they would like to dispose of?
    The normal problem is considerable wear at the end the bushes go, where the tie bar passes through the chassis mount. I dont need that end - only the other fork end and about 6 inches of the rod.
    Cheers, Robin
    Robin, you could look for a pair of Minor ones - that's what I used to save butchering the originals.
    • martinclan56
      • Feb 2020
      • 486
      Unfortunately they seem to not come up very often s/h. And a new set is getting on for £100....
      Cheers, Robin
