Spare set of Marlin keys?
  • Kahawi
    • Jan 2018
    • 159
    Erring on the side of caution, ‘Ur indoors’ is very keen on me getting a spare set of keys cut for ‘ULA’. (The garage remote is not the problem)
    The ‘Lowe & Fletchers’ and the Ford Sierra key I’ve hope for, at our local shoe-smith, cum photo print, cum dry cleaning shop.
    But what do we do about the passive ConLog fob?
    Very little reference ‘on the web’ and the company have long gone, I assume.
    Does anyone have any experience of disabling the alarm/immobiliser - In an emergency - In the dark - In the wet and in a layby on the A303, no doubt…..
    Last edited by kahawi; 15-02-23, 10:17 AM. Reason: Cannot understand how to include a photo, without all Hell breaking loose? Steep learning curve this new Foru...
    • 2797
    Try this :
    Write whatever you want, then “Enter” to put the curser on the next line (or two) down
    Hit “Upload Attachments” then click on the Insert size ( I like to stay below 600 pixels in each dimension if possible)
    Then “Post Reply” bottom right
    • droverpete
      • Dec 2014
      • 44
      My Hunter has a socket for the fob, next to the ignition switch, but I've never had or used a fob and the car starts fine. So in a previous ownership, or when built, the module must have been removed/disabled so it's possible.
      I looked in the Haynes Sierra manual, found no reference to it then realised Haynes might be in trouble if they published 'how to disable a Ford immobiliser'!
      Behind the carpet in front of the drivers door is a bundle of black wires and a multipin plug not connected to anything. From the back of the multipin, five go back to the fob socket, one is an earth, one goes to a relay and two disappear into the loom.
      Peter H
