Ignition module
    Ignition module
    I'm looking for an ignition module for a replacement 2.0 Pinto that Bob is going to transplant into my car in the new year. Not sure if it's Bosch or Lucas that I'm looking for yet but if you have something, know of one, can point me in the direction of one I would be interested. Will post the type when I know it but putting feelers out now.
    Thanks
    Re: Ignition module
    Hi Sue,
    I fitted "Lumenition" to my old Pinto. very pleased with it. Ah, this may be of no use to you if you are fitting the fuel injected version though, sorry.
      • 1237
      Re: Ignition module
      Bosch dizzy or motorcraft ? Then the type of electronic ignition? I have always found Burton very good tel no 020 8518 9122. Are you using a soc pinto? and just adding electronic set up? Or is the engine as supplied with electronic bosch dizzy and you are minus the module?
